Pressure and Density-based
Old   April 16, 2016, 03:15
Default Pressure and Density-based
yu lin chen
jojoora is on a distinguished road
I have a question about Pressure and Density based.
I would made the supersonic flow simulation so I choose Density-based. If I choose density-based, my ram were always working on 100% after initializing the solution, but if I chose Pressure-based, it works around 10%.
My computer's ram has 32 G.
I had checked my mesh quality. It's well.
jojoora is offline   Reply With Quote
Old   April 18, 2016, 15:28
Lucky
By 10%/100% are you referring to RAM capacity usage (in MB/GB) or RAM access speed?
The density base solver generally should only need 2x the memory of the pressure based solver. I honestly have never encountered a problem where the memory increased by more than 10x.
The density based solver solves coupled and these can more easily be accelerated. However, a 10x speed increase is still surprising unless there is a large disparity between your cpu and ram speeds cause by your hardware.
Wind tunnel Boundary Conditions in Fluent metmet FLUENT 6 October 30, 2019 13:23
Pressure based vs density based solver newbie384 FLUENT 2 July 5, 2013 03:04
Pressure vs. Density based jan FLUENT 2 May 3, 2007 04:45
Pressure based and Density based Solver Xobile Siemens 1 November 30, 2004 22:13
Warning 097- AB Siemens 6 November 15, 2004 05:41
