[Sponsors] | |||||
Sebastian
Rep Power: 0 ![]() |
Hi
I've got a problem with my shock tube simulation. I want to define in two zones (high pressure, low pressure) different gases. In one case the high pressure zone defined with helium and in low pressure zone with nitrogen. But if I do that, the result is incorrect and totally confuse. If I define all zones with same gases, the simulation works fine. Density-Based and transient Solver are used. Furthermore the simulation is inviscid and with ideal gas. Hope someone can help. Regards, Ambalo |
#2 | |
Edward Gan
Did you manage to figure out the correct way to do this? I'm having this same problem right now. Best regards, Edward |
| Tags |
| fluent, shock tube |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 22:43 |
| Vortex Tube Mesh and Simulation in Fluent | sankeerth2292 | FLUENT | 2 | March 13, 2015 23:52 |
| Modelling a shock tube in ANSYS Fluent | crustaccione | FLUENT | 1 | June 16, 2014 14:16 |
| Shock tube simulation | harish | FLUENT | 5 | January 25, 2014 03:20 |
| rhoCentralFoam not reflecting shock in Shock Tube? | Astaria | OpenFOAM Running, Solving & CFD | 5 | March 4, 2012 04:07 |
