June 28, 2011, 05:16 |
Porous zone coefficent
Ale
I must create a porous zone to simulate with fluent 13 a honeycomb and a screen in a Wind tunnel. But I don't know how to find the coefficients : Viscous resistance and inertial resistance. I read the help of Ansys but I cannot understand how to calculate these coefficients. I have the pressure loss and all the dimensions of the honeycomb and the screen. Cheers! |
June 28, 2011, 09:32 |
continue
Ale
I've change method: I use the porous jump, but I don't understand how it work... (strange eh?). if I try to find the coefficient of losses with the thickness and the loss of pressure it doesn't work. K = dp / thk Sorry i really need help, how does it work???? Cheers! |
May 4, 2016, 12:18 |
Polytimi Sofotasiou
Rep Power: 10 |
Did you find out which values should be applied for the honeycombs and screens?
honeycomb, inertial resistance, porous zone, viscous resistance, wind tunnel |
Modelling Combustion in Porous Zone | tanjinjack | FLUENT | 2 | September 26, 2016 04:10 |
boundary condition in porous zone | lihx | FLUENT | 4 | August 28, 2010 18:36 |
Need help!:Particle flow through porous zone | lig | FLUENT | 0 | April 26, 2010 00:47 |
Problem in IMPORT of ICEM input file in FLUENT | csvirume | FLUENT | 2 | September 9, 2009 01:08 |
Sliding mesh error | Karl Kevala | FLUENT | 4 | February 21, 2001 15:52 |
