Please HELP: Postprocessing_LES data
Old   May 17, 2016, 09:18
Unhappy Please HELP: Postprocessing_LES data
Kumar
pksri is on a distinguished road
Dear All,
I need some guidance from experts regarding my post processing of LES simulation. I am studying about BL transition phenomenon, for a simple flat plate geometry at a small incidence. I have done simulation with monitor points(lines) and saved data's for every 50time steps. I used Matlab to see the time averaged results. I herewith attached some plots.
1. CF: Skin friction coefficient for monitor points along the inclied plate in different z direction values. I feel the Cf value is bit weird compare to the Blasius solution for laminar and turbulent. Also, it approaches to zero around 0.52m, which I can say is the region of seperation. My question is is the Cf plot is meaningful? How do I conclude with this for transition?
2. Tavg_rms : Here we can see the flow starts fluctuating around 0.45m. so this is the point where it starts to behave has turbulent flow
3. Tavg_rms_x & xvel : RMS x fluctuation & Velocity along X, is plotted against Tangential direction (Y) at different stream wise direction to see the BL growth.
How can I conclude by saying that there is transition, which occurs in the region. The shear stress plot behaves as same as CF plot and I cant come to conclusion with shear stress or cf plot. what are all other values would give me a meaningful result to justify the transition phenomenon.
I would be more happy if someone could help me out. Looking for your valuable comments.
Kind Regards,
Kumar
pksri is offline   Reply With Quote
Old   May 23, 2016, 09:22
Unhappy
Kumar
someone could you please help me with the problem I am facing?
boundary layer flow, les, transition
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 07:31
[OpenFOAM] Paraview doesn't seem to be picking up data generated by icofoam MikeHersee ParaView 2 January 6, 2015 08:27
Data Produced From Fine Marine Cant Match with The Experimental Data PeiSan Fidelity CFD 4 August 23, 2014 05:33
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
