Residual spike while switching form serial to parallel.
Old   May 26, 2016, 10:41
Default Residual spike while switching form serial to parallel.
nm
nvarma is on a distinguished road
Can anyone explain why there is a spike in residuals as I switch (write cas and dat, open in parallel) from serial to parallel run on fluent?
nvarma is offline   Reply With Quote
Old   May 27, 2016, 10:12
nm
Update:
So not only is there a residual spike, it diverges immediately. The simulation can go on for thousands of iterations in serial but not even hundred on parallel.
Anybody?
Old   May 27, 2016, 18:27
`e`
`e` is on a distinguished road
Could you show us your mesh with the partitions outlined? Be careful of having partition boundaries where important flow characteristics occur (non-linear changes in velocity); especially if you're using a second order discretisation scheme (partitions only overlap one cell on the partition boundary). Have you tried running in parallel from initial conditions or only from a serial-produced result?
`e` is offline   Reply With Quote
fluent, parallel computing
Maximum number of iterations exceeded chtmultiregionsimpleFoam Moncef OpenFOAM Running, Solving & CFD 28 July 13, 2020 14:26
time step continuity problem in VAWT simulation lpz_michele OpenFOAM Running, Solving & CFD 5 February 22, 2018 19:50
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 02:20
Wrong fluctuation of pressure in transient simulation caitao OpenFOAM Running, Solving & CFD 2 March 5, 2015 21:33
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 13:12
