Continuity convergence problem
Old   May 29, 2016, 17:26
Default Continuity convergence problem
Fadi hajj
Fadih is on a distinguished road
hello guys,
I am simulating a 3D VAWT, i have created my geometry in ansysand used ansys meshing for the mesh. i am having a problem in fluent convergence of the continuity equation while all other criterions converge. i am using the SAS model for better accuracy of results and actually i am required to use this model. The first thing i did to try solving the issue is refine my mesh, i am up to 2.5 million nodes and the mesh propagation through the bodies is quite satisfying since the mesh is matched at interfaces so transition from a body to another should not be the problem, i did get an error in ansys meshing saying that inflation have created stair step mesh but when i launched fluent the mesh check quality didn't report any error also their is no divergence issue and even when i ran my simulation no warning showed up so i think that this is not the source of the problem. i chose my time step so the turbine rotates 0.27 deg/timestep.
i have no clue how to solve this, continuity keeps oscillating up and down.
Does anyone have any idea, would be greatly appreciated.
i have uploaded pics of the geometry and the mesh at the interfaces ( its just tetra mesh)
Fadih is offline   Reply With Quote
Old   May 29, 2016, 17:27
Fadi hajj
here are the remaining screen shots
Old   May 29, 2016, 18:42
hyugakojiro999 is on a distinguished road
Is your convergence criteria 10^0-6 or 10^-3 ?
Which of them is adequate for your situation?
What about mesh quality? Are they adequate including Y+ ?
Had u done validation before performing this analysis?
hyugakojiro999 is offline   Reply With Quote
Old   May 29, 2016, 18:59
Fadi hajj
mesh quality is something around 0.03 however the average quality is 0.85.
criterion is 1e-3 for all equations
yes i checked the quality and no warnings or errors showed up
y+ is around 80, in my case i don't need a low y+ because for the turbine Cp is mainly generated from pressure and not shear and does not require much clustering.
the bad quality mesh is around the blades due to stair syep mesh, i struggeled with that for 2 days but couldn't solve it but fluent didn't seem to have any problem with that, and the warning repair wall distance didnt even show up
i struggeled quite a bit with the mesh but i need to maintain a max of 3 million nodes so can't really insert a very low inflation which js currently at 1e-4
Old   May 29, 2016, 19:01
Fadi hajj
but what is weird is that Cm that i am monitoring is stable and close to experimental data
Old   May 29, 2016, 20:04
Are u using any UDF or UDmaterial? Check it twice
Try only default meshing to see if continuity will be converged.
Check even BCs.
Old   May 29, 2016, 23:34
Fadi hajj
no it doesn't that' s why i refined , no UDF just regular settings
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
Problem with convergence Iman Sengupta FLUENT 12 June 23, 2015 07:44
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
