Nanofluids in Fluent
Old   June 13, 2016, 06:13
Default Nanofluids in Fluent
Rahul
rahulkhatri2311@gmail.com is on a distinguished road
I am using Fluent to simulate nanofluids in heat exchangers, when i am validating the published results my surface nusselt No. is decresing while increasing the volume fraction of the nanoparticles in base fluid i.e. water.
This seems to be a problem in modelling as i tried two validation and found same pattern in both. Kindly convey if someone has any idea about it that why surface nusselt No. is decreasing when it suppose to increase with increase in volume fraction.
rahulkhatri2311@gmail.com is offline   Reply With Quote
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
heat transfer with RANS wall function, over a flat plate (validation with fluent) bruce OpenFOAM Running, Solving & CFD 6 January 20, 2017 06:22
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 13:41
Fluent crash on writing data file after thousand iterations Chuck87 FLUENT 0 September 2, 2015 16:17
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 16:48
