June 13, 2016, 06:13 |
Nanofluids in Fluent
Rahul
I am using Fluent to simulate nanofluids in heat exchangers, when i am validating the published results my surface nusselt No. is decresing while increasing the volume fraction of the nanoparticles in base fluid i.e. water.
This seems to be a problem in modelling as i tried two validation and found same pattern in both. Kindly convey if someone has any idea about it that why surface nusselt No. is decreasing when it suppose to increase with increase in volume fraction. |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 03:22 |
heat transfer with RANS wall function, over a flat plate (validation with fluent) | bruce | OpenFOAM Running, Solving & CFD | 6 | January 20, 2017 06:22 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
Fluent crash on writing data file after thousand iterations | Chuck87 | FLUENT | 0 | September 2, 2015 16:17 |
Problems in lauching FLUENT | Lourival | FLUENT | 3 | January 16, 2008 16:48 |
