Shadow Wall
Old   June 28, 2016, 16:00
Default Shadow Wall
Student_GF is on a distinguished road
Hello all,
I have a question regarding shadow walls. I am confused on why they are created? I am also confused on why a flow cannot pass the shadow wall into another fluid region.
Does anyone know why?
Thank you
Student_GF is offline   Reply With Quote
Old   June 28, 2016, 18:58
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
Fluent's documentation explains it very well
https://www.sharcnet.ca/Software/Flu...ug/node253.htm
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   June 29, 2016, 09:55
Hi diamondx,
Thank you for the link. I have another question regarding shadow walls that I was wondering you may help me with. The shadow wall is created between two fluid zones, one porous and the other is not. The fluid flow from the nonporous zone is not able to penetrate when there is this shadow wall. Do you know why?
Old   June 29, 2016, 15:38
nm
nvarma is on a distinguished road
just don't name the wall between fluid and porous zone when you create the mesh. name both as "fluid"
Or you could change the wall to "interior" and the wall will disappear.
As obvious as it is, there will be no flow across a wall.
nvarma is offline   Reply With Quote
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
Diiference between wall and wall shadow vbharath1947 FLUENT 2 April 15, 2014 08:16
Radiation interface hinca CFX 15 January 26, 2014 17:11
[Commercial meshers] tmerge utility creates unwanted interface/walls comes in the final mesh Shoonya OpenFOAM Meshing & Mesh Conversion 11 January 20, 2012 06:23
Wall Shadow interfering with Nusselt Number calculation? ryzd FLUENT 1 March 3, 2010 06:16
