Wind Turbine Fluent setup. Is it correct?
Like Tree5Likes
Old   February 5, 2012, 19:31
Default Wind Turbine Fluent setup. Is it correct?
federvo.mala is on a distinguished road
Dear all,
I am trying to simulate the NREL Phase VI experiment. Here is the setup I have done:
1) General
2) Cell zone conditions
I am treating the whole mesh as a whole Single Moving Reference Frame
3) Boundary conditions
a) inlet - velocity
The frame is absolute, right? Plus I am not sure what to put in the initial pressure gauge value. I only know the velocity value.
b) Blade/rotor
The blade is set a rotating wall
c) Far field
Note the difference in the frame. For the far field I have used absolute frame ( as specified by the user's guide)
d) Outlet: pressure outlet with 0 gauge pressure
4) Solution initialization
Is the reference frame correct?
To conclude, the things I am not really sure about are:
With this setup, the far field is affecting the whole flow because is set as wall, how can I set it to not influence the far field, something like open atmosphere or maybe a free-shear wall?
Have I set the Moving refererence frame correctly?
And what about the initial gauge pressure at the inlet bc?
Any help is greatly welcomed as I am a bit stuck and would really need some experienced help.
Thanks so much,
Federico
federvo.mala is offline   Reply With Quote
Old   February 6, 2012, 16:00
Default 3 Questions for you
zhenglun.wei is on a distinguished road
Dear Federico,
According to your questions,
A: As I know, outflow is good option. Conceptually, it just let the flow go out.
A: To my limited knowledge, it is correct. I tried it in a turbine simulation in aircraft engine case before.
A: No idea on this one.
After reading your thread, I have 3 questions:
1, I can not see the Fig.1;
2, Where did you get the mesh file for the NREL wind turbine? Is there any open source for that?
3, Why do you want to use wall roughness = 0? Are you assuming that the wind turbine is pure smooth?
best,
Alan
zhenglun.wei is offline   Reply With Quote
Old   February 7, 2012, 07:49
Originally Posted by zhenglun.wei View Post
Dear Federico,
best,
Alan
Dear Alan,
First of all thanks for your reply.
1. I will upload fig.1 again although it's not important at all.
2. I built the geometry on solidworks and then created the mesh on ICEM CFD. It is an unstructured mesh with prism layers around the blade. I can give you the geometry if you want.
3. I set the blade as no slip. I though this would be only straightforward option.
Here some other questions for you:
1. What bc shall I use for the outlet? Do you think that pressure outlet at 0 pascal would do the job?
If you need any more info regarding the NREL let me know.
Thanks,
Fred
Old   February 7, 2012, 11:17
I always try the 'Outflow' first. You may try it to see if there is any problem like 'reversed flow'. If no, you can use 'Outflow' for simplicity. To my experience, I use 'Pressure Outlet' only when I come across unexpected 'reverse flow' problem. Hope this helps. ^_^
Alan
Old   February 7, 2012, 15:25
Alan
Hey Alan thanks again,
and you said outflow for the farfield too?
I have tried giving it 'velocity-inlet' with the same value as the free-stream velocity, with the difference that instead to 'normal to the boundaries' I put it parallel to the boundaries. It seems to work too but it may be wrong too :S
Thanks
Old   February 7, 2012, 17:07
^_^ I tried that to deal with unexpected 'reversed flow' issues before. It helps.
Alan
Old   February 8, 2012, 21:33
Alan
OK, if then you use outflow for both outlet and far field, how do you set the 'mass flow weighting' ? 1 for both?
Old   February 8, 2012, 22:07
Yes, I just assume the flow is equally devided for all out flow boudaries.
Old   February 8, 2012, 22:29
Makes sense. Cheers
Old   March 24, 2012, 02:40
john doe
zaheerd21 is on a distinguished road
Dear Federvo,
I am trying to do this same simulation in Fluent but am also stuck. Did you get yours to work? If so, then could you please advise me on how you changed yours from the pictures you have shown above? Also could you please advise me on which turbulence model you used and what discretisation schemes you used?
Thank you.
zaheerd21 is offline   Reply With Quote
Old   March 25, 2012, 21:22
Default Blade B.c
  #11
mohamed khedr emam
m5edr is on a distinguished road
Hi All
I also asking about the Blade B.c
why federvo set the Blade >> rotating wall (relative to adj.) instead of setting it "stationary"
(the default in rotating reference frame, that walls rotate with
the grid, and hence are moving.)
thanks
m5edr is offline   Reply With Quote
Old   March 27, 2012, 21:36
Abdulqadir Aziz
aqstax is on a distinguished road
Originally Posted by zaheerd21 View Post
Dear Federvo,
Thank you.
The following thread may be of use. http://www.cfd-online.com/Forums/flu...i-turbine.html
aqstax is offline   Reply With Quote
Old   June 2, 2012, 06:31
monaya flower
monaya flower is on a distinguished road
Dear Federvo,
1- i think that the far wall must be symmetry in the bc
2-in MRF you should use relative velocity formulation
3- for the blade condition i think it is right
i want to ask about why you use intemittency , k and omiga rather than intenesity and viscosity ratio
and if you get accurate result how did you calculate the power extracted from the wind turbine
thank you
monaya flower is offline   Reply With Quote
Old   June 9, 2012, 19:02
Originally Posted by monaya flower View Post
Dear Federvo,
thank you
HI
1 - yes you are right. Changed to symmetry in my final model.
2 - probably right, but I always used SRF
3 -
I indeed used k-w with intensity and viscosity ratio specs.
I first extracted the torque from Fluent and then calculated power (available) via a simple formula....
What are you working on?
Best,
Fred
Old   June 11, 2012, 17:27
monaya flower
Hi
I 'm doing numerical simulation of shrouded wind turbine . and i can't calculate the torque .
I know that torque would be calculated from report - moment , but i can't specify x,y,z coordinates correctly. can you help me ?
what moment i should take if the rotating axis is x ?
why did you use SRF rather than MRF .
Old   June 15, 2012, 06:30
You should put '1' on the x axis and leave '0' for the other axis.
For a horizontal axis SRF is fine (based on literature) and suggestions. Although for a vertical one things are different.
Old   June 15, 2012, 11:13
monaya flower
Hi Federvo
thank you for your reply .
first Are you sure about using SRF ? cause i read the literature about HAWT and they were used MRF .
if you used SRF, what is in your opinion bc should i set to get good results?
Old   June 15, 2012, 13:10
Hi Federvo
100 % sure you can use SRF as well as MRF. If you like people also used sliding or dynamic mesh. Up to you
Velocity-inlet
Pressure-outlet
Far-field (semi circular face) = Symmetry
Plane faces of the domain = periodic
Blade = as shown in the pics above
Fred
Old   June 17, 2012, 23:59
cuteapathy is on a distinguished road
I have a similar question here. I had the mash which made in OpenFOAM and converted it to the mesh type for Fluent. In OpenFOAM, there are two kinds of mesh, one part, the outside cylinder, is static mesh and the other part, the wind turbine inside the smaller cylinder, is dynamic mesh, which is rotating. When I tried to run this case, it did not work. The case only runs in the initial second and can not run for more seconds. The wind turbine can not rotate at all. I am wondering whether I need to redefine or reset up the dynamic mesh. I have no idea how to fix this. Could anyone kindly give me some advice? Any advice would be helpful. Thank you.
cuteapathy is offline   Reply With Quote
Old   June 30, 2012, 19:44
Default direction
  #20
Sarah4
sarah4 is on a distinguished road
Hello Federvo
I am wondering why your flow direction is -1 for "Y" direction, while your rotational direction is +1 for "Y".
I can see from your picture your turbine rotates +Y, then flow direction (from inlet to outlet) should be +1.
Am i right? Or i missed something?
Thanks.
sarah4 is offline   Reply With Quote
Porous media setup issues in Fluent Bernard Van FLUENT 29 January 26, 2017 04:09
Torque of wind turbine simulation caohan FLUENT 8 August 11, 2014 23:01
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Simulating a Göttingen type wind tunnel in FLUENT Chris FLUENT 3 December 4, 2006 17:33
Virtual Wind Tunnel in FLUENT ND FLUENT 0 April 7, 2006 07:43
