July 20, 2016, 04:56 |
DPM approach for spray drying
Saxony Anhalt
Rep Power: 10 |
Dear All,
I am trying to do a DPM modeling for the flow dynamics of particles and air inside a spray dryer using ANSYS Fluent. My confusion might be under rated but I am stuck with it since a week now. The model apparently seems easy and might also be but I am confused about few things. I have attached a picture of the geometry as well as geometry file if someone wants to look into it. Firstly, I am confused about the negative volume (fluid extraction) inside the spray dryer body. Should I use certain operations like fill or enclosure in order to model the flow dynamics or does assigning the body as Fluid body is enough? Secondly as there an outlet pipe inside the dryer, I am not very sure how to proceed with this? Should the pipe be as a solid body or a fluid body? And should I use certain Boolean operations for the pipe like subtract or not? For now all the bodies I have kept as frozen. I would be very grateful if anyone could give an insight to this problem. I merely need an advice or a guidance to what path or necessary steps I should follow that align with my problem. I look forward to helpful responses. Thank you very much. I have attached two pictures one from Design Modeler, and other to see Boundry conditions in Fluent. Kind regards, Umair Jamil Last edited by umairjamil; July 20, 2016 at 07:42. |
ansys, design modeler, volume extraction |
Euler-Euler and Euler-Lagrangian approach on similar model and comparison | Armi | Fluent Multiphase | 0 | June 1, 2016 06:18 |
Coupling of drying process and flow simulation | franzdrs | Main CFD Forum | 0 | April 29, 2013 14:11 |
how to use DPM from DPM file unsteady? | Cloud | FLUENT | 0 | November 10, 2011 04:25 |
Drying of particles | Mohsin | FLUENT | 0 | October 25, 2011 05:34 |
dpm approach to a solid liquid fludized bed... | bhanwar | Main CFD Forum | 0 | July 5, 2011 02:28 |
