HVAC - Radiation Boundary Conditions
Old   July 25, 2016, 05:32
Default HVAC - Radiation Boundary Conditions
Alex Gtz
alex_gtz is on a distinguished road
Hi everyone,
I am trying to model an entrance hall will a window-wall on one side. Other walls (including floor and ceillings) are considered adiabatic.
My questions concerns the boundary conditions I should enter at walls and window-wall. For the window-wall I know that, by convention heat transfer coeff is 8 W/m^2.K at the inside and 23 W/m^2.K at the outside. Which one should I put in FLUENT for the window-wall ?
Free stream temperature is the temperature of the outside. BUT, what is external radiation temperature ? I did put the same temp than the free stream temp but I am not sure at all if I'm right...
For walls, is the free stream temp the temp of the inside (fluid-domain) ? And external radiation temp the temp of the exterior environment ?
Last question, I put 0.006m as the wall thickness (for the window-wall) but it doesn't seem to change anything, does anybody know how wall thickness work ?
I know that all of these questions are not really related to FLUENT, it is related to radiation knowlegde in general but I can't find good documents on the internet, If somebody could enlighten me that would be very helpful !
Thank you. Alex.
alex_gtz is offline   Reply With Quote
Old   July 27, 2016, 04:35
CT
cturutoglu is on a distinguished road
You should use the inside heat transfer coefficient value for convection. I have no idea about radiation temp but i guess you can use the free stream temp which is the temp of the outside.
Wall thickness is only meaningfull when you work on a heat conduction problem.
cturutoglu is offline   Reply With Quote
Old   July 27, 2016, 16:01
nm
nvarma is on a distinguished road
You cannot specify heat transfer coefficient or free flow temperature on wall side facing the fluid. this is taken care by the fluent code and turbulence model.
so the values you enter are for the outside (no fluid zone, ie. end of domain)
nvarma is offline   Reply With Quote
Old   August 2, 2016, 08:10
Default what about wall thickness then
Alex Gtz
If I follow your idea then FLUENT will compute the heat transfer by conduction depending on the thickness of the wall...
Trying to find the correct Radiation Boundary Conditions volleyHC OpenFOAM Pre-Processing 2 November 27, 2015 06:38
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 17:30
Setting rotating frame of referece. RPFigueiredo CFX 3 October 28, 2014 04:59
Radiation Modeling Chris89 CFX 20 August 14, 2014 07:51
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source silvan CFX 3 June 16, 2014 09:49
