Fluent Adjoint Solver Convergence Issue?
Old   March 1, 2013, 05:39
Default Fluent Adjoint Solver Convergence Issue?
Malik
ex10148 is on a distinguished road
Hello Everyone!
Case:
Optimisation of front wing of a formula one car using Fluent Adjoint Flow Solver
Issue found:
With the conventional flow solver the residuals tend to converge within 350 iterations using k-epsilon turbulence model with standard wall function. But with the adjoint flow solver it diverges. Issue seems to be in the control settings of the adjoint flow solver. Images are included for the current settings used and the residual history for both the standard flow solver and the fluent adjoint flow solver.
I would really appreciate if any of you could help me where I might be going wrong. Your help will be much appreciated.
Thanks a lot and best regards,
Ahmed.
ex10148 is offline   Reply With Quote
Old   June 2, 2013, 16:45
alexandrepaes is on a distinguished road
Originally Posted by ex10148 View Post
Hello Everyone!
Case:
Issue found:
Ahmed.
Hi, Ahmed
I've been working with fluent's adjoint solver on the last months.
Have you ever solved your problem? I'm dealing with the same issue.
How did you adjust your adjoint control's factors?
alexandrepaes is offline   Reply With Quote
Old   July 25, 2016, 14:41
Lennart
elmo555 is on a distinguished road
Hey there,
did you ultimately get your calculation to converge?
I'm using the adjoint solver in R17.1, and I fixed my convergence issue by enabling stabilization (Adjoint Solution Controls -> Use Stabilized Scheme) with default settings. Now it converges, but very slowly.
Does anybody have tips on those parameters?
elmo555 is offline   Reply With Quote
adjoint solver, fluent, fluent adjoint solver, fluent convergence, fluent solver
convergence and off wall spacing issue josip76 FLUENT 0 June 4, 2011 18:13
fluent convergence problem josip76 FLUENT 0 May 26, 2011 20:08
Fluent 12.1 on Linux x64 Architecture Issue fivos FLUENT 5 April 24, 2010 15:19
Convergence Definition of Segregated Solver Amir FLUENT 0 April 18, 2006 06:21
Monitoring Convergence in Fluent 5.0 Tom Plikas Main CFD Forum 0 April 6, 1999 17:10
