August 4, 2016, 22:45 |
how to merge divided face
JungHo Lee
Rep Power: 11 |
Hello.
I have a problem for meshing. Dummy geometry was imported and there are many faces in dummy model. Because of these faces, mesh is excessive even though its size was controlled by mesh sizing option(mesh - insert - sizing). Is there anyway to improve mesh quality in this situation? The imported geometry image was attached below. Thanks. |
August 5, 2016, 08:38 |
#2 | |
Onur Özcan
Rep Power: 12 |
first you should select face in top bar (vertex,edge,face,body). Then you can choose which one will be merged without making worse your model surface. In conclusion, in same way you should select edges in case which faces are merged. Kind Regards, |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
