How to apply Neumann Boundary condition in Fluent
Like Tree1Likes
  • 1 Post By Luttappy
Old   September 2, 2016, 16:26
Thumbs up How to apply Neumann Boundary condition in Fluent
HK
Luttappy is on a distinguished road
Dear all
I would like to know how to apply Neumann Boundary condition in ANSYS Fluent for zero normal derivative condition at outlet of a channel.
Do we need to write UDF for that or we can apply existing boundary condition in fluent
Thanks in advance for any help or comment.
nikos_ likes this.
Luttappy is offline   Reply With Quote
Old   May 24, 2017, 14:50
Default Use of Outflow boundary condition
HK
Finally i found that Outflow boundary condition is suitable for my case.
Fluent manual says that
The boundary conditions used by FLUENT at outflow boundaries are as follows:
A zero diffusion flux for all flow variables.
An overall mass balance correction.
The zero diffusion flux condition applied at outflow cells means that the conditions of the outflow plane are extrapolated from within the domain and have no impact on the upstream flow. The extrapolation procedure used by FLUENT updates the outflow velocity and pressure in a manner that is consistent with a fully-developed flow assumption, as noted below, when there is no area change at the outflow boundary.
The zero diffusion flux condition applied by FLUENT at outflow boundaries is approached physically in fully-developed flows. Fully-developed flows are flows in which the flow velocity profile (and/or profiles of other properties such as temperature) is unchanging in the flow direction.
It is important to note that gradients in the cross-stream direction may exist at an outflow boundary. Only the diffusion fluxes in the direction normal to the exit plane are assumed to be zero.
Old   April 24, 2018, 13:32
yomnag is on a distinguished road
hello i am facing the same issue so you mean that outflow boundary is the same as neumann
yomnag is offline   Reply With Quote
Old   April 25, 2018, 00:29
Kumaresh
Kummi is on a distinguished road
Send a message via Yahoo to Kummi
Go with outflow if you need to implement Neumann boundary condition - for normal derivative condition at outlet.
Kummi is offline   Reply With Quote
ansys fluent, boundary conditions, neumann bcs
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 05:15
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 13:41
several fields modified by single boundary condition schröder OpenFOAM Programming & Development 3 April 21, 2015 05:09
How to transfer boundary condition from Openfoam to fluent sachinlb OpenFOAM Post-Processing 1 January 6, 2012 01:41
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
