Solid State Diffusivity UDF
Old   September 8, 2016, 11:14
Default Solid State Diffusivity UDF
typhoon1010 is on a distinguished road
I am new about udf. I am trying to write UDF which is related to thermal diffusivity. (Local Thermal Non-Equilibrium Model / Solid state energy equation)
This is code. I try to define material panel and it did not run. I did not understand UDS's logic.
My question are
1 - How can I define Ts (Solid State Temperature)
2 - What does if (i==TS) mean
I would be glad if you help.
# include "udf.h"
# define zeta 0.38
# define TKS 16.591
DEFINE_DIFFUSIVITY (uds_diffusivity, cell, thread, i)
real source,Ts;
if (i == TS)//if solid state temperature
/*source = (1-porosity)* (Thermal conductivity of solid)*/
source = ((1-zeta)*TKS);
else source = 0.0;
return source;
typhoon1010 is offline   Reply With Quote
Old   September 8, 2016, 15:14
nm
nvarma is on a distinguished road
You need to get the cell or face temperature into a variable.
like T=F_T() or C_T() (refer manual)
then compare this with TS (solid state temp) which you have to define using #define.
The code has some syntax and semantic errors. (TS not defined anywhere, i==TS doesn't make sense at all)
Refer udf manual and look at the examples there.
nvarma is offline   Reply With Quote
Old   September 10, 2016, 10:41
This code run. But When I can define solid state temperature (#define Ts something). It did not run.
Do u know How can I define solid state temperature.
#include "udf.h"
#define TKS 10
#define SOLID_THERMAL_COND(Ts) 2
#define SOLID_DENSITY(Ts) 3
#define SOLID_CP(Ts) 2
enum { SOLID_TEMP };
DEFINE_DIFFUSIVITY( uds_diffusivity, cell, thread, i )
real source;
real Ts;
if (i == SOLID_TEMP)
Ts = C_UDSI(cell, thread, SOLID_TEMP);
source = (SOLID_THERMAL_COND(Ts) / (SOLID_DENSITY(Ts)*SOLID_CP(Ts)));
else source = 0.0;
return source;
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
Fluent Radiation/porous media Schmitt pierre-Louis FLUENT 26 September 1, 2016 10:29
UDF for solid volume of fraction Capricorn Fluent UDF and Scheme Programming 0 March 22, 2016 04:06
UDF diffusivity (strain rate)-UDS Lilly Fluent UDF and Scheme Programming 0 September 6, 2013 02:47
UDF Multicomponent Diffusivity with Knudsen term Emmanuel Resch FLUENT 0 August 8, 2008 21:01
