Fluent: Flow won't interact with rotating region
Old   September 26, 2016, 11:30
Default Fluent: Flow won't interact with rotating region
TOlsen is on a distinguished road
Hi everyone,
Some little problem, My project is to do a 2D Vertical Axis wind turbine analysis. This is a 2D analysis. I have set up FLUENT with no problem,
there are 2 region, the boundary and rotating. Both have define interface.
ANSYS version is 16.0 so it's contact region in Mesh Interface tab.
The model is create in Solidwork and export to STEP.
Airfoil is NACA 0018
Angular velocity is at 25 rad/s
Inlet velocity is 20 m/s
Outlet is atmospheric
However, the result flow is seem not to interact with the rotating region at all, it's like they are both separated flow entirely.
How could I make the flow interact? Should I specify a porosity?
Screen:
Best, and thanks for your time!
T. Olsen,
TOlsen is offline   Reply With Quote
flow, rotating region, vawt, vawt wind turbine
Periodic flow using Cyclic - comparison with Fluent nusivares OpenFOAM Running, Solving & CFD 30 December 12, 2017 05:35
Viscoelastic flow modeling in Fluent Ankur Navra FLUENT 3 July 26, 2013 05:56
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
[ASK] Flow in Corrugated Pipe with FLUENT Primadhani FLUENT 1 May 11, 2011 20:41
How Fluent treat the pressure term in imcompressible flow Ray FLUENT 1 May 24, 2000 16:50
