error C2109: subscript requires array or pointer type --on drying simulation--
Old   November 9, 2016, 03:05
Default error C2109: subscript requires array or pointer type --on drying simulation--
meljuntak
Melvin is on a distinguished road
Hi everyone...
I am a Ph.D. Student with research about simulation of coal drying. In my simulation I use UDF based on DPM multicomponent model as shown in UDF Guide for DPM_Heat_and_Mass_Transfer, I use Ansys Fluent 12 version with the transient model, injection of particle occur on 60 t0 61 second, as much as 600 gr. After I compile my UDF there are occur error as shown below
multivap.c(56) : error C2109: subscript requires array or pointer type
multivap.c(57) : error C2109: subscript requires array or pointer type
This error due to part of udf line 56 and 57
56 P_total += cvap_surf[ns];
57 dens_total += cvap_surf[ns] * molwt[gas_index];
Did someone ever do this case and how to solve the problem??
Whether this simulation needs to be initialized vaporization and injection must be written in UDF also???
Thankyou very much
Melvin
My complete UDF was written as below
#include "udf.h"
DEFINE_DPM_HEAT_MASS(multivap,p,Cp,hgas,hvap,cvap_ bulk,cvap_surf,dydt,dzdt)
int ns ; /*declaring variable ns as an integer*/
int nc = TP_N_COMPONENTS( p ); /* number of particle component */
real dens_total = 0.0; /*total vapor density*/
real P_total = 0.0; /*vapor pressure*/
cell_t c0 = RP_CELL( &(p->cCell) ); /* cell and thread */
Thread *t0 = RP_THREAD( &(p->cCell) ); /* where the particle is in */
Material *gas_mix = THREAD_MATERIAL( t0 ); /* gas mixture material */
Material *cond_mix = p->injection->material; /* particle mixture material */
cphase_state_t *c =&(p->cphase); /*cell info of particle location */
real molwt[MAX_SPE_EQNS]; /* molecular weightf gas species */
real Tp = P_T(p); /* particle temperature */
real mp = P_MASS(p); /* particle mass */
real molwt_bulk = 0.; /* average molecular weight in the bulk gas */
real Dp = DPM_DIAM_FROM_VOL( mp / P_RHO(p) ); /* particle diameter */
real Ap = DPM_AREA(Dp); /* particle surface */
real Pr = c->sHeat * c->mu / c->tCond; /* Prandtl number */
real Nu = 2.0 + 0.6 * sqrt( p->Re ) * pow( Pr, 1./3. ); /* Nusselt number */
real h = Nu * c->tCond / Dp; /* Heat transfer coefficient */
real dh_dt = h * ( c->temp - Tp ) * Ap; /* heat source term */
dydt[0] += dh_dt / ( mp * Cp );
dzdt->energy -= dh_dt;
Material *sp;
mixture_species_loop(gas_mix,sp,ns)
molwt[ns] = MATERIAL_PROP(sp,PROP_mwi); /* molecular weight of gas species */
molwt_bulk += C_YI(c0,t0,ns) / molwt[ns]; /* average molecular weight */
/* prevent division by zero */
molwt_bulk = MAX(molwt_bulk,DPM_SMALL);
for( ns = 0; ns < nc; ns++ );
/* gas species index of vaporization */
int gas_index = TP_COMPONENT_INDEX_I(p,ns);
if ( gas_index >= 0 )
Material * cond_c = MIXTURE_COMPONENT(cond_mix, ns ); /*condensed material*/
real vap_temp = MATERIAL_PROP(cond_c,PROP_vap_temp); /* vaporization temperature */
real D = MATERIAL_PROP_POLYNOMIAL(cond_c,PROP_binary_diffus ivity,c->temp); /* diffusion coefficient */
real Sc = c->mu / ( c->rho * D ); /* Schmidt number */
real k = ( 2.0 + 0.6 * sqrt(p->Re) * pow( Sc, 1./3. ) ) * D /Dp; /* mass transfer coefficient */
real cvap_bulk = c->pressure / UNIVERSAL_GAS_CONSTANT / c->temp
* c->yi[gas_index] / molwt_bulk / solver_par.molWeight[gas_index]; /* bulk gas concentration */
real vap_rate = k * molwt[gas_index] * Ap * ( cvap_surf - cvap_bulk ); /* vaporization rate */
if( 0. < vap_rate && Tp < vap_temp )
vap_rate = 0.;
dydt[1+ns] -= vap_rate;
dzdt->species[gas_index] +=vap_rate;
dydt[0] -= hvap[gas_index] * vap_rate / ( mp * Cp ); /* dT/dt = dh/dt / (m Cp) */
dzdt->energy += hgas[gas_index] * vap_rate; /* gas enthalpy source term */
P_total += cvap_surf[0, ns]; /*vapor pressure = vapor equilibrium concentration of vaporizing components*/
dens_total += cvap_surf[0, ns] * molwt[gas_index]; /*Total vapor density = mol/m3 *kg/mol*/
Melvin is offline   Reply With Quote
Old   November 10, 2016, 22:08
meljuntak
After I make some adjust, the UDF can run. but the problem still occurs that no interaction between evaporated moisture (from particle) and drying air. The Humidity of dry air always same even though particle moisture content decrease. Did someone in this forum know how to solve this problem?. What UDF must be added to solve this problem??? Is it possible by added udf about mass and energy exchange will solve the interaction between continuous phase and discrete phase?? Thanks.........
i run the model again (after compiled the UDF), the simulation get error again...how come it occur?????
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
Boundary Conditions MtnRunBeachBum OpenFOAM Pre-Processing 1 April 30, 2015 16:33
singularity? mihaipruna OpenFOAM Running, Solving & CFD 5 April 24, 2012 17:18
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 17:08
