Central axial velocity drops too fast for round jet flow using LES |
November 14, 2016, 03:29 |
Huifeng
Rep Power: 9 |
Hi all,
I am simulating the turbulent round jet air flow from a nozzle tube (5mm in diameter) with LES, and the results shows that the mean axial velocity along the centerline drops much faster compared with experimental data, can anyone give me some comments? The inlet boundary is located at the nozzle tube outlet, and a mean velocity profile is specified according to the experimental data with UDF. SGS model is Smagorinsky-Lilly Model, and the spectral synthesizer is used to provide the fluctuation with a turbulent intensity of 5%. other settings are just given according to FLUENT manual. Thank you! |
Baldwin-Lomax model in wall jet flow | K.S.Chang | Main CFD Forum | 0 | December 7, 2005 01:51 |
LES on two phase flow | Li Yang | Main CFD Forum | 0 | May 12, 2004 08:10 |
flow simulation across a small fan | jane luo | Main CFD Forum | 15 | April 12, 2004 17:49 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
