[Sponsors] | |||||
Giulio La Bella
Rep Power: 0 ![]() |
Hi all,
I'm simulating a 2D flow over an airfoil with FLUENT. I'm using LES as model. The simulation runs without problems, but when I stopped the simulation and tried to open it again this happened: read --> case worked normally, but read --> data gave me the following error: Error: received a fatal signal (Segmentation fault). Error: received a fatal signal (Segmentation fault). Error Object: #f Error: Error reading "C:\Users\xxxxx\Desktop\xxxxx\xxxxx\fluent-3-05000.dat". Error Object: #f I'm not using UDF. If I read case and data from other simulations I did (for example with k-w model ecc.) it all works fine. What can be the problem? Thanks you all. Giulio |
Rep Power: 12 ![]() |
Hi Giulio
check the UDFs, if you're using some |
Giulio La Bella
Thank you! Fixing the UDFs worked!
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Problem in compiling fluent UDF lunched from MATLAB | cfdman10 | Fluent UDF and Scheme Programming | 16 | December 5, 2019 06:32 |
| Fluent Mixed Convection Problem | cfdsolver1 | FLUENT | 7 | September 19, 2016 05:58 |
| Can I solve this problem by Fluent? | Kai_kc | FLUENT | 1 | October 27, 2010 06:29 |
| LES using FLUENT | sarah_ron | FLUENT | 7 | October 22, 2004 18:36 |
| Rev: Can Fluent 6.0.20 predict this problem right? | Yazid Bindar | FLUENT | 5 | March 6, 2003 04:09 |
