gravity on or off?
Old   December 1, 2016, 03:39
Exclamation gravity on or off?
SinaJ
sina_mech is on a distinguished road
I'm dealing with a big geometry (internal flow), in which the vertical distance from bottom to the top is around 50m. It's single phase and surrounded by walls.
My only concern is that since I'm doing a particle tracking on it, I need to apply the gravitational force on the particles for that purpose.
Should I apply Gravity during the fluid flow iterations or not?
The convergence with gravity-off is nice! with gravity-on the convergence is not easily achievable (still I can get something), but the streamlines look weird and there are many incomplete streamlines!
PS: I'm using realizable k-e with scalable wall function.
sina_mech is offline   Reply With Quote
Old   December 1, 2016, 05:07
Onur Özcan
oozcan is on a distinguished road
what do you solve exactly in FLUENT ? gravitional affect may be important for your model or not. That is relation to your expectation. No gravitonal effect affect Navier Stokes equation. That is why your model is easily convergenced (negligible gravity)
oozcan is offline   Reply With Quote
Old   December 1, 2016, 07:55
Antanas is on a distinguished road
It seems you're modelling multiphase flow and your particles are moved by buoyancy forces. Am I right? If so you must activate gravity. Take in mind that buoyant flows are not easy to converge especially using steady-state solver, often they should be modeled as transient with appropriate time stepping. Also you should carefully specify reference density/temperature and BC.
Antanas is offline   Reply With Quote
Old   December 1, 2016, 12:56
SinaJ
It's a single-phase water flow through a huge internal system. and I'm trying to see the rate of sedimentation of solid particles in that. I was wondering that maybe I can solve the fluid first (with no gravity), and then activate the gravity and try the DPM-particle tracking.
Old   December 1, 2016, 12:58
SinaJ
That's the part I'm debating. It's not multi-phase. I mean, it is, but my solution approach is a single-phase fluid simulation and then tracking the particle's trajectory in the fluid.
simpleFoam with gravity, based on interFoam JonW OpenFOAM 1 May 9, 2019 10:08
Convergence problem when use gravity aroma STAR-CCM+ 1 April 10, 2013 10:18
Question on Gravity archdevil Main CFD Forum 9 May 16, 2012 13:31
Ok to increase gravity gradually from 0 to 9.82? Admo FLUENT 3 February 23, 2012 10:43
On gravity modelling... Drona CFX 7 November 22, 2001 10:28
