Multiphase models
Old   December 1, 2016, 07:41
Default Multiphase models
Bhoomin Chauhan
Bhoomin17 is on a distinguished road
I am trying to simulate mixing of air and methane in a counterflow reactor in fluent. Now, I'm a little confused about which multiphase model to use? Should I go for mixture as it deals with mixture momentum equations and prescribes relative velocities to describe the dispersed phases or opt for VOF or Eulerian?
Any help would be appreciated.
Bhoomin17 is offline   Reply With Quote
Old   December 3, 2016, 07:12
Quang Le Dang
SPH_CFD is on a distinguished road
It depends on mass fraction and what you want to get in model
If mass fraction of air is small, you can use mixture model otherwise Euler-Euler model.
Besides, you should consider what kind of results you want to get in model. For example, if you think catch interface is important, so go with VOF.
But in your case, maybe interface is not so important. So, mixture model or Eulerian is enough
SPH_CFD is offline   Reply With Quote
Old   December 3, 2016, 14:29
SinaJ
sina_mech is on a distinguished road
As Quang mentioned, if you're not interested in interface-capturing, mixture model would be a better (easier) choice. Just make sure you reach a good convergence, cause fore example sometimes you see converging residuals, but you second phase has not even reached to the outlet of the domain (if an outlet exists though!)
sina_mech is offline   Reply With Quote
Old   December 3, 2016, 15:37
Bhoomin Chauhan
Thank you for your replies. I appreciate it, and I do have an outlet. Right now, I am just trying to figure out how well these two liquids will mix. I also have to do the combustion analysis, but, that comes later on. Also, if it's possible, can you explain me how this phase thing works? I'm not sure if I understand it correctly.
Old   December 3, 2016, 15:42
SinaJ
which part is confusing? Please specify.
Old   December 3, 2016, 15:45
Bhoomin Chauhan
Like, if I assign air as phase 1 and methane as phase 2 will the results differ if I put methane as phase 1 and air as phase 2?
Old   December 4, 2016, 08:14
Quang Le Dang
https://www.sharcnet.ca/Software/Flu...ug/node890.htm
Guys, Please take a look. It is very in details for you
Old   December 4, 2016, 23:10
Bhoomin Chauhan
Thank you.
Multiphase models cfd project FLUENT 1 November 6, 2016 07:32
Tips for air entrainment/bubbles? + steady state multiphase models Apocolapse STAR-CCM+ 0 February 17, 2013 08:07
Using more than one solver models in Multiphase problem Fascal FLUENT 0 July 7, 2010 16:25
Incompressible Turbulence models achinta OpenFOAM 4 May 27, 2010 10:35
how to use MIXSIM to simulate multiphase models weiz FLUENT 1 November 26, 2009 00:40
