ANSYS Fluent rotation of SOLID drum filled with water
Old   October 26, 2019, 09:49
Default ANSYS Fluent rotation of SOLID drum filled with water
P
coms0 is on a distinguished road
Hi everybody,
I am using ANSYS Fluent to simulate the rotation of a drum (made of titanium as external walls) and filled with water (so basically a rotating cilynder with a water volume inside and titanium external walls).
I 'm having though problems in the rotation settings of the solid external part: after having set the liquid solid interfaces between titanium walls and water volume, in the "setup" when I try to apply the rotational velocity to the solid walls the only way I can do this is to activate the "frame motion" in the solid body (under cell zone conditions) imposing a rotational velocity of 63 rad/s. While in the boundary conditions section, the "momentum" of the solid wall boundary is not active (since it's solid).
But doing this way I noticed that the titanium walls don't rotate, I tried with different settings (making also the water wall boundary rotating), setting the same rotational velocity to the interfaces and other methods but I didn't manage to make the solid walls rotate.
Could you please tell me how I could solve this problem and make the solid body rotate?
Or maybe Fluent doesn't allow rotation of solid geometries?
Thank you in advance for your help.
Best,
P
coms0 is offline   Reply With Quote
ansys fluent, rotation, solid
Solid object falling in water tank simulation cassini83 CFX 3 August 9, 2021 17:05
Ansys SIG$ILL error loth ANSYS 3 December 24, 2015 05:31
How to combine ANSYS Fluent and Structural analysis? diwakar ANSYS 2 June 18, 2015 12:07
[DesignModeler] Importing Solid Edge ST4 Geometry into Ansys Fluent 13.0 for meshing The Mighty Rearranger ANSYS Meshing & Geometry 0 November 27, 2012 12:44
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 07:10
