December 7, 2016, 03:26 |
UDF compilation error
samrat himvanth nanduri
Rep Power: 13 |
hi while building the UDF if getting the following error " The program cant start because fl1300s.exe is missing from your computer" can some1 help me fix this..
Thanks in advance... |
December 7, 2016, 11:24 |
Quang Le Dang
Rep Power: 13 |
December 7, 2016, 23:34 |
Rep Power: 13 |
hi Quang Le Dang,
thank you for your reply... my windows is up to date... my fluent setup has been done properly because i'm able to run simulation. Only thing i am not able to do is compiling UDF... can you please point out where things could have gone wrong in the installation process so that i can rectify it... Thanks... |
December 8, 2016, 06:52 |
Quang Le Dang
Rep Power: 13 |
I think, you should use a very simple UDF to test what is really happening. Also make sure your UDF file is the same folder with your case.
Sent from my LG-F260S using CFD Online Forum mobile app |
December 13, 2016, 11:57 |
Rep Power: 11 |
I think you don't have a C compiler coupled with Fluent to compile the UDF. Maybe try to interprate the UDF but I don't know if it will correct your problem. Fanch |
December 14, 2016, 04:23 |
mohamed hares
Rep Power: 10 |
I had a problem in compiling udf
....... and it gone after installing microsoft visual studio ......... try it |
December 14, 2016, 16:45 |
Rep Power: 14 |
It could be because the case file you are trying to load already has a precompiled UDF in it. But that was done on a different PC. You need to remove that hooked UDF and compile it again on your PC.
December 15, 2016, 23:50 |
Rep Power: 13 |
thnak you gys.. i had sorted the problem out...thanks again
Pressure outlet boundary condition | rolando | OpenFOAM Running, Solving & CFD | 62 | September 18, 2017 06:45 |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 11:39 |
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! | alban | Fluent UDF and Scheme Programming | 2 | June 8, 2010 18:54 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 09:30 |
How to get the max value of the whole field | waynezw0618 | OpenFOAM Running, Solving & CFD | 4 | June 17, 2008 05:07 |
