About flow around a circular cylinder using Fluent |
December 15, 2016, 10:03 |
Green
Rep Power: 10 |
Dear all. I am performing flow around a circular cylinder in Fluent. The density is 1000kg/m3, the viscosity is 5 pa*s. The cylinder diameter is 0.5m and the width of flow path is 1m, the length of it is 4m. The inlet velocity is 0.5m/S.
So Reynold number Re=1000*1*0.5/5=100 After calculation I get a pair of stable vortices in the wake. We all know there is laminar vortex when 40<Re<150. And the cell Reynolds number contour shows that the reynolds above the cylinder is about 13. Why? I got 100 from my calculation. I use laminar of viscous model and don’t have a boundary mesh. Thank you very much. |
December 15, 2016, 10:14 |
Cees Haringa
as you say, it's the cell reynolds number. It's based on the fluid properties in that grid cell, the velocity in that grid cell, and the lengthscale of that grid cell. It has nothing to do with the cylinder reynolds number that you calculated.
December 15, 2016, 20:44 |
Green
Rep Power: 10 |
Thank you.
I know cell Reynolds number is not the same with that i calculated. But the flow field seemed to be not consistent with the reynolds I calculated. |
December 15, 2016, 20:45 |
#4 | |
Green
Rep Power: 10 |
December 15, 2016, 20:52 |
Rep Power: 18 |
A few comments:
December 15, 2016, 21:05 |
#6 | |
Green
Rep Power: 10 |
I use no-slip condition on the top and bottom sides. The effective Re is higher. But the flow field seems to be the same with ever. I will try to consider the drag. After applying inflation layers I get the same results as before. After increasing the mesh size it seems the same. |
fluent cylinder reynolds |
fixed circular cylinder for a steady flow in lamina regime: getting strange Cd values | virtuoso | FLUENT | 1 | February 4, 2015 09:45 |
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 11:47 |
DSMC results of low-Mach flow over circular cylinder | flotus1 | Main CFD Forum | 2 | November 13, 2012 10:37 |
flow around a cylinder | pXYZ | Main CFD Forum | 14 | July 25, 2011 10:05 |
Modeling flow acros circular cylinder | Zhihua | Main CFD Forum | 3 | April 20, 2004 11:16 |
