January 6, 2017, 03:40 |
mesh independence
mahya
Rep Power: 9 |
Hello
I have a particle in a tube And i want to cheak mesh independency What should i do? |
January 6, 2017, 03:49 |
NGP
Rep Power: 10 |
you should create new mesh 50 percent finer. run the solution. and compare the answer with previous result. if there is no change , you approach the mesh independency.
January 6, 2017, 03:52 |
#3 | |
mahya
Rep Power: 9 |
That was correct But when i change mesh My results is different from each other |
January 6, 2017, 04:10 |
NGP
Rep Power: 10 |
how many new mesh you create?
January 6, 2017, 04:13 |
mahya
Rep Power: 9 |
January 6, 2017, 04:45 |
NGP
Rep Power: 10 |
January 6, 2017, 10:51 |
Lucky
Rep Power: 66 |
Remesh. Rerun. Compare the results. That's the general idea. In general, the solution will change, because there is mesh dependency in the discretization. The question is how significant is the change in the result?
Look up Patrick Roache's grid convergence index for a cute method to quantify mesh dependence. You can also run a coarser mesh. |
January 8, 2017, 02:16 |
Rep Power: 9 |
Consider a tee pipe which has two inlet and one outlet let us have in one inlet pipe 5 lpm and in one inlet 7 lpm the output must be unique as 12 lpm by conservation of mass considering no internal effects. For studying mess independence we must have unique solution. Meshing and analysis of this pipe at outlet must always produce 12 lpm whatever mesh we provide we want the unique solution for studying mesh independence
Sent from my HTC Desire 526GPLUS dual sim using CFD Online Forum mobile app |
January 8, 2017, 02:48 |
Rep Power: 9 |
Refine your mesh and retry
January 8, 2017, 06:41 |
Rep Power: 11 |
What are the Parameters that should kept constant?such as courent number or timestep
Sent from my ZTE Blade V6 using CFD Online Forum mobile app |
Transient mode simulation (VoF model) mesh independence study problem | yulu | FLUENT | 4 | September 20, 2016 17:30 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
Mesh Independence - Valid Strategy? | Ianto | Main CFD Forum | 2 | August 31, 2009 04:36 |
