Conjugate heat transfer, interface and walls
Old   January 9, 2017, 06:42
Default Conjugate heat transfer, interface and walls
saimen
saimen is on a distinguished road
Dear CFD community
I have been struggling with a coupled heat transfer problem for quite a while now and tried to look for a solution in your forums but could not find any answer.
For simplicity, my model contains a tube (solid domain) with water (fluid domain) flowing on the inside at laminar conditions. I defined the geometries and created a contact between the inner tube surface and outer water surface before generating the mesh.
When I want to setup up my solution, I have a src and trg interface for both domains. I can make a coupled wall by selecting these two interfaces and ANSYS automatically creates 4 new boundary conditions:
- side1-wall-contact-src (wall) -> can choose BC
- side2-wall-contact-trg (wall) -> can choose BC
- wall1-1-1 (wall) -> coupled selected
- wall1-1-1-shadow (wall) -> coupled selected
My question now is, why does ANSYS create 4 new walls?
I would just like to have coupled heat transfer across the interfaces. However, I also have to set BCs for the src and trg walls but I only know the outside surface temperature of the pipe and have no information on the heat flux.
Does ANSYS need a HTC as input or can it calculate this value directly from correlations using flow conditions and thermal properties? In case I need to insert a HTC, which wall should I choose (src, trg or both)?
I would be very glad to have some answers. Maybe I got confused with some stuff and hope some of you could help me with the understanding.
Best Regards!
-saimen
saimen is offline   Reply With Quote
Old   January 10, 2017, 11:47
saimen
I think I found the solution. Before creating the mesh, I have to select all bodies in the DesignModeler, right click and "form body". Now when I create the mesh and go to the setup procedure, I see a wall and shadow wall for both domains. They are already defined as coupled and this seems to work.
One other question: When I want to include S2S radiation, which wall do i have to choose for the view factor calculations, the shadow walls or normal walls? Because I can only change the emissivity in the shadow walls, so I used those for the view factor calculation.
Best,
saimen
Old   January 11, 2017, 04:33
Dmitry Volkind
dvolkind is on a distinguished road
Hi, Saimen!
S2S model works in fluid domains only, so you don't have to care about solid side of the coupled wall. But fluid side is not always "shadow" - that's geometry dependent. To tell which wall is which you can simply judge by available BC settings. There is also a text box in the BC menu, indicating its neighboring cell zone.
dvolkind is offline   Reply With Quote
Old   January 11, 2017, 04:44
saimen
Hi dvolkind,
Thanks for your quick reply! I was thinking about the same thing, but someone posted a long time ago that you don't have to include shadow-walls.
But that is really geometry dependent!
Regards,
saimen
Old   April 12, 2017, 00:44
Default Heat transfer coefficient
scholar is on a distinguished road
Dear Sir,
I have to calculate the inner heat transfer coefficient of a helical coil inside which cold water is flowing. I have created the geometry in Gambit. Kindly help me with the steps to carry out the heat transfer process in Fluent.
Thank you.
scholar is offline   Reply With Quote
Old   August 15, 2019, 04:54
zhou tong
tong6061 is on a distinguished road
Step 1. On mesh step, u should specify the connects. (automatically will connects,connects1, connects2...)
Step 2, On Setup/ solution.
if solid-fluid interface, it will have different name, like wall-1,wall-2,etc
Step 3, go to mesh interfaces, delete the old interfaces and create new interface, u should choose' coupled' or "mapped" (same thing, just mapped is more robust).
Step 4, it will automatically create 4 walls, (2 shadows and 2 normals), the two shadows u just need set as coupled, and 2 noramls set the bc (generally u dont need set anything to it, it will automatically calucalte, if zero thickness, it will perfect conduction).
tong6061 is offline   Reply With Quote
Conjugate Heat Transfer: Wall Heat Flux at Coupled Walls? MaxHeat FLUENT 4 September 14, 2017 10:44
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 04:39
Heat Flux at Internal walls or Fluid Solid Interface Mahi CFX 3 October 1, 2012 02:18
Conjugate heat transfer and radiation modeling questions shankara.2 FLUENT 0 April 21, 2009 15:55
modeling interface in conjugate heat transfer Vivek FLUENT 5 October 12, 2007 05:43
