January 18, 2017, 22:15 |
steady analysis
manar
Rep Power: 9 |
Hello Guys
I have a question regarding the steady analysis : *How to justify the fluid velocity if it is a steady state problem , I know if the fluid is moving that mean it does not come to steady-state completely n is there any criteria for that ? *about convergence : are the default residuals minimum ? what if I got 2.5e-2 for continuity residual for example ?????/? |
January 19, 2017, 02:29 |
Rep Power: 18 |
You're wrong. Based on conditions flow can come to steady-state regime which means that its parameters don't change with time in every spatial point of flow region, that is flow pattern is steady (frozen) in time.
January 19, 2017, 04:53 |
manar
Rep Power: 9 |
thanks Antanas
sorry I am not familiar with Fluent that much , what I got from you is that Fluent consider steady state when the fluid parameters come into zero in the edges , ie:Outlets and walls , Is that correct ? |
January 19, 2017, 10:45 |
Lucky
Rep Power: 66 |
It might be clearer if you call it steady-flow. The rate of flow attains a steady value (velocity is time-independent).
Velocity going to zero at walls is a boundary condition. Velocity =0 at an outlet is paradoxical, either there is no flow or it is not an outlet. |
January 19, 2017, 11:52 |
Rep Power: 18 |
Not at all. It's not about Fluent, it's about physics. Steady flow regime means that in the process of fluid flow its parameters (velocity, pressure, density etc.) at every point in the flow don't change with time. Understand? In steady flow parameters may vary only spatially.
January 21, 2017, 20:19 |
manar
Rep Power: 9 |
very clear Antanas and Lucky Tran
cfd, fluent |
Eigenfrequencies static and modal analysis | Laura_mecheng | ANSYS | 1 | May 15, 2012 03:40 |
3D analysis of Ahmed body | Irshad22 | FLUENT | 0 | December 17, 2009 04:33 |
pls help.How to do thisblade passage analysis ??? | kaen | FLUENT | 0 | January 19, 2006 08:54 |
how to do blade passage analysis of turbine? | kaen | FLUENT | 0 | January 17, 2006 22:49 |
Using turbulence model for steady state analysis | Terry | FLUENT | 7 | February 28, 2001 07:03 |
