How to draw time varying graphs in cfd-post ? |
January 27, 2017, 00:52 |
Gary
Rep Power: 9 |
Hi, I am new to the forum and also somewhat new to CFD. I was working on a project on analysing blood flow in aneurysmic aortas and was able to setup a solve the transient solution using fluid flow flow(fluent). Before solving I had created a solution data export for the following variables :
1. Static pressure 2. Total Pressure 3. X Velocity 4. Y Velocity 5. Z Velocity 6. Wall Shear stress After soving I had opened the results in CFD-post and could successfully run the timestep animations of velocities, pressure (as contours), and wall shear stress (as a surface group in the aneurysm wall). However I cannot plot the variation of wall shear stress with time. I tried to create a chart and specify the type as XY-Transient or Sequence, but could not specify any locations. Capture.PNG Can anyone suggest me a method of this plot. I even tried to create a surface monitor for wall shear stress with flow time but it showed 0 variation throughout the iteration which is obviously not true. |
January 27, 2017, 01:24 |
B.A.K
Rep Power: 10 |
Change the type of the plot as XY histogram under the General tab, and then your Y axis will be time axis. Under X axis tab you can select which variable do you want to plot.
Regards B.A.K |
January 27, 2017, 02:13 |
Gary
Rep Power: 9 |
Thanks. I tried the histogram plot. But it is showing only one value in each particular range. However in the surface group animation there are a number of contours varying with flow time.
Capture 2.jpg Capture 3.jpg The graph with which I want to compare is not a histogram looks somewhat like one of these: Capture 4.PNG Is there any way I can plot the values which are being animated in the wall shear stress (varying with timesteps) with time to get a curve like one shown above? Please help. Last edited by Gourabc; January 28, 2017 at 03:26. |
August 7, 2020, 18:35 |
wahba
Rep Power: 5 |
hey,
did u find how to get the time graph? |
August 9, 2020, 17:40 |
Bruno
Rep Power: 21 |
I hope they did, cause it's been 3 years
What was missing was that they needed to create a point (Location > Point) and then use that at the Location field. Cheers. |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
[solidMechanics] solidMechanics gear contact in rotation | nlc | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 3 | January 11, 2015 06:41 |
Help for the small implementation in turbulence model | shipman | OpenFOAM Programming & Development | 25 | March 19, 2014 10:08 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
