February 24, 2017, 06:03 |
Courant number
srrmm27
1.why does fluent solve problems by bringing down global courant number to 1 when the limit is upto 250? Why doesnt it solve at 249 or within that range?
2. can we use the source terms for multi-phase vof model, while the linearised mass transfer udf remains at "yes" state? if yes, then what difference does it make as compared to using source terms with linearised mass transfer udf being at "no" state Many thanks |
February 25, 2017, 00:38 |
Lucky
Rep Power: 66 |
1) Fluent does a stability check and if it thinks the solution is diverging, it will reduce the time-step.
[General] Extracting ParaView Data into Python Arrays | Jeffzda | ParaView | 30 | November 6, 2023 21:00 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
Sudden jump in Courant number | NJG | OpenFOAM Running, Solving & CFD | 7 | May 15, 2014 13:52 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
