Velocity profile in a rectangular cavity
Old   March 4, 2017, 08:13
Default Velocity profile in a rectangular cavity
Thomas
Arttis is on a distinguished road
Hello there,
I am trying to find how the velocity varies at the cross section of the cavity.
The air is flowing due to Buoyancy force (Bussinesq model, adiabatic side walls and constant temperature specified at the Top Wall and the Bottom Wall).
No slip condition is imposed at all the walls, which means that the maximum velocity should be in the middle of the cavity.
However, as it can be seen from the attached pictures, the maximum velocity appears to be closer to the walls. Does anyone understand, where could my problem be?
Also, I can't get velocity streamlines. The Contour shows the velocity but once I try to insert the streamlines, nothing comes up. I tried changing Mesh but it appears to be the same.
Thank you,
Thomas
Arttis is offline   Reply With Quote
Define velocity profile for cavity arriftou Fluent UDF and Scheme Programming 6 September 21, 2023 03:23
3D rectangular velocity profile UDF Chalke06 Fluent UDF and Scheme Programming 3 August 6, 2016 13:37
Patch fully developed velocity and turbulence profile over full domain Teumde FLUENT 2 June 29, 2015 13:47
Velocity profile interpolation FLUENT Mustafa1986 FLUENT 3 April 28, 2015 03:23
Parabolic velocity profile in a rectangular channel nithishgupta OpenFOAM Running, Solving & CFD 3 October 30, 2013 05:39
