Heat transfer problem at nucleate boiling
Like Tree1Likes
  • 1 Post By MrStuebb
Old   July 15, 2010, 17:11
Default Heat transfer problem at nucleate boiling
MrStuebb is on a distinguished road
I´m trying to simulate nucleate boiling of an ammonia-water-mixture by fluent 6.3. in a pipe with turbulent flow and eulerian multiphase model. Therefor I´m using the udf of the "Nucleate Boiling"-Tutorial by Fluent. For this udf I defined two boundary conditions for the interior wall, one for the solid side (wall) and one for the fluid side (wall-shadow). The mesh on the fluid side got a very fine boundary layer.
My Problem:
The solution doesn´t show any heat transfer between wall and fluid. I´m sure that material data, entered in fluent and udf, are correct because I tried to iterate the tutorial data with original udf on my mesh in the same way the tutorial do. But no heat transfer occurs.
If there is someone with an idea for solving my problem I´m thankful for telling me.
best regards
mrstuebb
MrStuebb is offline   Reply With Quote
Old   August 13, 2010, 11:57
Default Boiling model
Khurram
deep_seak is on a distinguished road
Hi. I am also trying to simulate the same tutorial case and having the same problem. I even tried to model the same geometry as the tutorial's one and also import the original mesh file in gambit and then exported it again and run the solution. But in all the above cases no heat transfer occured. If you find any answer then please send me at deep_seak@yahoo.com
deep_seak is offline   Reply With Quote
Old   January 7, 2011, 11:59
late, but better than never
try to change the wall-shadow and wall-shadow-shadow boundaries of the pipe wall with each other. When I remind correct, it was the failure in my case.
rolin212 likes this.
Old   February 27, 2011, 09:56
Hamdy
hamdy is on a distinguished road
Sorry, but i have similar problem. Could you plz send me the boiling tutorial on my mail: hamdy.abotaleb@yahoo.com
Thanks
hamdy is offline   Reply With Quote
Old   May 21, 2011, 01:34
majid sattarcheh
majidsa6 is on a distinguished road
hi my friend,
if u send for me your udf code i can help u
because i should run it in fluent and i answer to u for your error
majidsa6 is offline   Reply With Quote
Old   June 12, 2011, 22:08
gleb
Ghalebsater is on a distinguished road
Hello guyz, Is there a UDF for 3d or the given 2d udf from the tutorials will work on any 3d model. Any idea??
Ghalebsater is offline   Reply With Quote
Old   April 4, 2012, 07:57
raoudha
raoudha is on a distinguished road
My Problem:
best regards
mrstuebb
hello mrstuebb
I´m also trying to simulate two phase flow of an ammonia-water-mixture by fluent in vertical tubes, my problem is how to define the materiel properties of water-ammonia mixture, could you help pleaaaase
thank a lot
raoudha
raoudha is offline   Reply With Quote
Old   April 4, 2012, 14:18
as far as I can remember we calculated the material properties according to the volume rates of water and ammonia in the mixture and entered it as one phase into FLUENT. In FLUENT you have the possibility to determine the material properties as a function of temperature.
The properties of vaporization of the mixture were determined in a UDF-function, related to the temperature and pressure of the mixture.
I hope I this will help you!
Old   April 11, 2012, 08:23
raoudha
thank you very much i'll try this, hope it works
best regards
Old   April 25, 2012, 12:05
raoudha
dear MrStuebb
i'm still trying to write the UDF for ammonia-water mixture properties, could you pleaaaaaaaaaaase help me with en example cause it's the first time i deal with UDfs and it seems a little complicated, would you help pleaaase, my mail is " garma_raoudha@yahoo.fr "
with lot of thank
Old   December 18, 2014, 14:35
Ahmed F. AL-Neama
ahmedalneama is on a distinguished road
Sorry, but i have similar problem. Could you please send me the boiling tutorial on my mail: ahmad_alniema@yahoo.com
Thanks
ahmedalneama is offline   Reply With Quote
Old   March 27, 2016, 11:41
jigneshrohit
jigneshrohit99 is on a distinguished road
can anyone provide me tutorial of nucleate boiling of in horizontal pipe?
can anyone tell me where to download fluent tutorials pdf and zip files?
jigneshrohit99 is offline   Reply With Quote
Old   March 14, 2017, 13:31
  #13
Rag
RAG
Rag is on a distinguished road
Hi guys,
I am also trying to simulate Nucleate boiling using ANSYS in a 3D model.
I am using Eulerian 2 phase flow model with RPI boiling implicit.
But while running the calculations, it is showing 'Floating point exception' error.
What it mean?
Has Any one have the tutorials?
is there any UDF should be included?
Please, Anyone here!!
I need your Help!!
Thanks in advance.
d_Rag
Rag is offline   Reply With Quote
inverse heat transfer problem siva0182 FLUENT 6 February 22, 2019 06:00
BOILING HEAT TRANSFER COEFFICIENT John CFX 3 April 4, 2012 17:50
Conjugate heat transfer problem hvem10 FLUENT 2 October 29, 2009 17:31
heat transfer problem. vipin CFX 2 July 18, 2006 10:05
Boiling heat transfer calculation david CFX 0 June 21, 2005 04:17
