March 21, 2017, 11:23 |
flow focusing (sample+sheath) VOF problem
caroline
Rep Power: 9 |
Hello!
I started Fluent, my simualtion is a microchip with a flow focusing. 2 inlets and 1 outlet. The 2 inlets are both water, but different velocity. This is the microchip : 3.PNG Which model should I use? I want this kind of result. exemple.jpg Thank you so much for your help!! Last edited by Cmaroline; March 22, 2017 at 10:42. |
March 22, 2017, 07:57 |
Microfluidic flow in Fluent
valerie
Rep Power: 10 |
Flow in this kind of device are often laminar, so you should start with the default configuration of Fluent.
March 22, 2017, 08:05 |
caroline
Rep Power: 9 |
Thank you for your answer.
How can I differenciate the two phases even if it's the same fluid? Do I put VOF model? |
March 22, 2017, 08:12 |
Multiphase model
valerie
Rep Power: 10 |
It depends on the type of flow. If it is for surface tracking, VOF is appropriate.
March 22, 2017, 08:33 |
caroline
Rep Power: 9 |
The flow is laminar. But for observe flow focusing I need a primary phase -> sample and a secondary phase -> sheath. But my problem here is on the sheath channel (after input sheath) I don't have any velocity or any pressure increase. I don't know how I can solve this issue.
March 22, 2017, 08:44 |
valerie
Rep Power: 10 |
VOF should work for this kind of flow. What do you mean by 'I don't have any velocity or any pressure increase.'
March 22, 2017, 08:49 |
caroline
Rep Power: 9 |
I got a velocity different of 0 only on the region where the channel is pinched, somewhere esle the velocity is equal to 0.
But I don't understand because I differenciate the two velocities. And for the volume factor of sheath and sample I put 0 to sheath on the sample inlet and 1 to sheath on the sheath inlet. I don't found good results.... |
March 22, 2017, 08:53 |
caroline
Rep Power: 9 |
I tried a lot of parameters combinaison but I don't find the good result..
March 22, 2017, 08:58 |
valerie
Rep Power: 10 |
If you switch off the vof model and use only a single fluid with the same properties, do you observe a velocity field different from 0?
March 22, 2017, 09:08 |
caroline
Rep Power: 9 |
No! The entire microchip is blue (velocity equal to 0).
March 22, 2017, 10:45 |
#11 |
valerie
Rep Power: 10 |
The problem is not the vof in this case. could you give more details (screenshots) of your setup? What are your boundary conditions for both inlets and outlet? How many iterations do you run?
March 22, 2017, 11:02 |
#12 |
caroline
Rep Power: 9 |
I choose VOF with primary phase -> sample secondary phase -> sheath in bondary conditions I put in sheath and insample on velocity inlet, with both velocity and after for other bondary conditions, screenshots. Is it enough?
Iterations equal to 100.22-031.PNG22-03.PNG |
March 22, 2017, 12:18 |
#13 |
valerie
Rep Power: 10 |
Could you test with a much larger velocity for instance 1m/s? Do you a transient solver or a steadt solver?
Sent from my ALE-L21 using CFD Online Forum mobile app |
March 22, 2017, 23:19 |
#14 |
Lucky
Rep Power: 66 |
This isn't a VOF problem.
A much simpler way is to use a passive scalar and use it as a tracer to see which water is which. |
March 23, 2017, 03:21 |
#15 |
caroline
Rep Power: 9 |
Thank you Tigrgrou but it is a kind of exercize and I must apply theses velocities.
LuckyTran, I will try your method and I'm comming back towards you |
March 23, 2017, 03:53 |
#16 |
valerie
Rep Power: 10 |
Tracer is a good idea if both fluids have the same properties. Pathline could also be checked to evaluate there is a problem.
March 23, 2017, 07:56 |
#17 |
caroline
Rep Power: 9 |
Unfortunately when I program pathlines the software crash.... I got the student version for the moment (free version)
March 23, 2017, 08:47 |
#18 |
caroline
Rep Power: 9 |
LuckyTran I try to found how create a passive scalar but I don't know how I can do! Can you help me please?
March 23, 2017, 10:46 |
#19 |
Lucky
Rep Power: 66 |
It would help if I use the correct verbiage. It's actually a user-defined scalar in Fluent. You define the scalar in parameters & customization. I forget the details but one thing to be careful with is the diffusivity, you need to make sure that the scalars have the same properties as each other and as the actual fluid (water), not only the laminar/molecular diffusivity but also the same turbulent Schmidt number so that you have the same effective diffusivity.
In the user's guide, it's in in 8.1 User-Defined Scalar (UDS) Transport Equations |
March 24, 2017, 06:02 |
#20 |
caroline
Rep Power: 9 |
My issue is that I just have both velocities intlet and not much. I don't know how I can found the laminar/ viscosity properties and turbulent Scmidt number.
Help: apply B.C. in my granular flow model ? | Derek Jing | FLUENT | 1 | January 8, 2020 21:38 |
parallel code | samiam1000 | SU2 | 3 | March 25, 2013 04:55 |
Multiphase flow problem | icedou | FLUENT | 6 | July 10, 2005 02:52 |
