Effect on winglet mesh over drag
Old   March 22, 2017, 12:18
Default Effect on winglet mesh over drag
Ferruccio Rossi
frossi is on a distinguished road
I am simulating flow over a wing with winglet at different angles. The picture shows the winglet angle at 27 degrees. Since I wanted to capture the flow around the winglet in greater detail, I reduced the element size around the winglet. This also reduced the height of the inflation layer, creating what you see in the picture. Is it a problem?
After I run the simulation and check the drag values, they seem to oscillate randomly, despite changing the winglet angles for each simulation.
Can someone please explain why I cant get a pattern of increasing or decreasing drag?
The mesh pictures show a cut plane through the mesh.
Thanks.
frossi is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
[snappyHexMesh] Snappyhex mesh: poor inlet mesh Swagga5aur OpenFOAM Meshing & Mesh Conversion 1 December 3, 2016 16:59
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
