Continuity residual
Like Tree3Likes
  • 1 Post By Jin-Wook LEE
  • 2 Post By Greg Perkins
Old   March 21, 2002, 16:55
Default Continuity residual
Ferraris
hi every one :
I have a little problem with the conticuity residual. I m modelling a 3d natural convection problem and it seems not easy reduce this residual in particular. I am using linear aproximation of the density like force source in the momentum equation, and i m not sure what this continuity residual means.
I could not find this explanation in the manuals .
Thank you in advance.
Sergio
Old   March 22, 2002, 02:03
Default Re: Continuity residual
Jin-Wook LEE
You can be advised by the Fluent's 'HELP' option.
Help --> Index --> Definition of residuals.
Sincerely, Jinwook
Abhya likes this.
Old   March 22, 2002, 06:21
Greg Perkins
I've found that often problems with continuity stem from a poor mesh. Making a better mesh often helps the continuity equation residuals.
(though I've done very little natural convection..)
An easy way to check is to use grid adaption on your existing grid in regions where residuals are high. If this works, you can then go back and create a better starting grid. I also suggest using hexas or quads if possible in preference to tets and tris.
Greg
behnam87 and kamyab like this.
Old   March 23, 2017, 13:07
Default Continuity residual after restart
Paolo
paolofug87 is on a distinguished road
I faced a problem after restarting a transient simulation after a stop without changing anything.
The issue is that the continuity residuals (only) skip on a upper value.
Who could explain this?
Tks in advance
paolofug87 is offline   Reply With Quote
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
