Heat transfer coefficient at wall
Like Tree2Likes
  • 1 Post By oozcan
  • 1 Post By LuckyTran
Old   March 23, 2017, 23:06
Default Heat transfer coefficient at wall
Tleja
Tleja is on a distinguished road
Hi everyone
I'm working for gas-solid in fluidized bed reactor.
My system description, I packed solid at the buttom of reactor, then i feed gas throughout the reactor with 400K of temperature gas feed. I also kept the wall temperature as constant value of 350K.
The result from this system, I can get the realistic temperature profile of solid and gas.
As my knowledge, The wall heat flux at the wall should be calculated from
Q=hw(Twall-Tg)
Q= wall heat flux;
***hw= heat transfer coefficient;
Twall= temperature at wall;
Tg= Temperature of gas at the first layer of cell from wall;
Can anyone let me know how fluent calculate heat transfer coefficient of each phases at the wall??
Best regard
Tleja
Tleja is offline   Reply With Quote
Old   March 24, 2017, 01:40
Onur Özcan
oozcan is on a distinguished road
heat transfer made by conduction or convection are always equivalent (e.g. medium-solid, solid-fluid,solid-solid- fluid-fluid) . So,that is, you say ''at the wall''you can get only one heat transfer coeff. That is forced-convective heat transfer coeff. Moreover, I could not get Tg. How could you know that that temp. is first layer of cell from wall. You could just give your model boundary conditions and you could get results in compliance with your mesh. You could not know it which temperature gradient has in first layer cell from the wall. Moreover, the equation is to be solved in ANSYS-Mechanical in this way but not FLUENT.
Tleja likes this.
oozcan is offline   Reply With Quote
Old   March 26, 2017, 03:00
Lucky
LuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura about
There is a variable called something like wall temperature which actually gives you the fluid temperature of wall adjacent cells.
Tleja likes this.
LuckyTran is offline   Reply With Quote
Old   March 27, 2017, 02:56
Tleja
Thank you so much for your kindly help
At the moment, i found out how to calculate convection at the near wall in ANSYS theory as
HTML Code:
http://www.afs.enea.it/project/neptunius/docs/fluent/html/th/node99.htm#stdwf
This information is really good for me. I hope that will be useful for who is studying in heat transfer
Best regard
Tleja
Is it possible to set constant heat transfer coefficient at a wall? jpina CFX 8 December 24, 2021 05:29
How To Calculate Average Heat Transfer Coefficient in CFD-Post? Shomaz ul Haq CFX 16 November 24, 2019 18:57
Heat transfer coefficient near the wall in two phase flow XavierW Main CFD Forum 0 February 18, 2016 10:37
Thin Wall Heat Transfer BC for rhoSimpleFoam swahono OpenFOAM Running, Solving & CFD 12 October 4, 2013 11:49
Wall heat transfer coefficient (HTC) problem Mohamed khamis CFX 1 January 15, 2010 23:12
