April 21, 2017, 14:14 |
convergence problem
Danial
Rep Power: 9 |
hello dear friends,
I'm going to model a one phase flow, using k-epsilon model. I can't get good convergence as I use low velocity for water inlet (like 0.1 m/s), but as I set high velocity it reaches good convergence(like 5 m/s). what is the problem, what should I do? Is it a mesh problem? thanks in advanced |
April 24, 2017, 02:52 |
SinaJ
Rep Power: 16 |
I would try these solutions:
- Decrease the turbulent intensity to 2% or even 1% (you should actually calculate it rather than using default number or arbitrary values!) - Use K-Omega SST with low-Reynolds flow option enabled However, keep in mind that having a lower Reynolds number, increases the importance of viscous term in Navier-Stokes equation, and leads to a boundary layer with a larger thickness. Saying that, I mean since you're using a turbulence model, you need a good (proper) prism layer in that case. |
Convergence problem in Fluent for quenching process | kaeran | FLUENT | 4 | December 1, 2014 02:14 |
Rotate frame reference convergence problem! | wjy-c | CFX | 2 | September 26, 2014 06:03 |
Centrifugal pump OpenFOAM, convergence problem, ANSA model | RDD | OpenFOAM Running, Solving & CFD | 0 | July 5, 2014 09:12 |
Convergence Problem in Axisymmetric Periodic Flow | atheresia | FLUENT | 3 | February 10, 2014 03:00 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
