October 23, 2020, 03:00 |
large domain with large aspect ratio
ashkan
Rep Power: 5 |
hello,
I have a very large domain with a very large aspect ratio. domain is a pool with a very small hole in it. pool is a cube with 10 *10*10 km and the hole diameter is 20 cm! is there any way to simulate this type of problems without large mesh number? like scaling down or other methods? thanks very much |
October 24, 2020, 17:16 |
Lei Chen
Rep Power: 16 |
Hi Ashkan, you may try to solve this problem with probably two methods:
1. use conformal mesh but gradually growing mesh size, you may try to use cut-cell mesh in ANSYS mesher; 2. a more easier way is to use interfaces between the local fine mesh region with small mesh sizes, and a broader region with large mesh sizes. Specifically to your problem, with 5 orders of magnitude change, you may need several transitions to ensure a good continuity convergence; Other than those, is CFD really the best way to model your km domain? Or you may want to use the CFD results from the small region to provide a B.C. to the larger domain flow problem. Hope this helps. |
Sudden increase the residual of Maxwell's equations | hsezsz | CFX | 2 | October 13, 2016 06:58 |
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation | volleyHC | CFX | 5 | April 3, 2016 05:41 |
simpleFoam convergence on large domain | kwiik | OpenFOAM | 43 | May 31, 2013 10:10 |
Question about the large expansion ratio influence to the numerical accuracy | Anna Tian | Main CFD Forum | 8 | September 27, 2012 04:54 |
Grid Aspect Ratio | harishameed33 | Main CFD Forum | 1 | August 11, 2012 22:35 |
