May 7, 2017, 08:24 |
Heat Conduction / Cooling problem
Antono
Rep Power: 9 |
This is my very first post here. I am trying to perform 2D transient simulation of cooling down some object by stream of air. Assumptions: -Square object (Solid / Copper material - default properties) is inserted into the rectangle mesh (Fluid / Air material - default properties). Picture 1. MESH of the problem Models: Energy ON, Viscous (Laminar). Interface: I created two interfaces during meshing. I have deleted the default interface connection and created my own in the solver. Coupled walls type. Picture 2. Coupled wall interface window BC: Surrounding walls are adiabatic (insulated), velocity-inlet on left (293K, 1m/s), pressure-outlet on right. The square has walls with convection thermal condition option selected (Heat transfer 10000, free stream 300, wall thickness 0.001 and cooper material type). Shadow wall is also Coupled wall type and cooper material. Picture 3. BC on square wall I patch the square initial temperature to be 350K or more, (air flowing is 293). Results: While i run my calculation for 0.05 time step / no. of iteration 1000 let's say. I got very strange results. The air flowing by the square is heating up - that is correct. But the square reamains in the same temperature to matter how long air is flowing. I did simulations for 2 seconds and for 300 seconds. It looks like there is only heat transfer from the square to flowing air but no cooling of the square is vissible. Picture 4. RESULTS !!Please, can somebody help me how to perform such simulation to see that the block with patched initial temp. is cooling down? Thanks, Adam |
cooling, heat conduction, heat transfer |
Problem with total heat transfer rate | aswathy_raghu | FLUENT | 9 | April 21, 2022 10:36 |
Heat Transfert, mixing problem | Wazdq | CFX | 8 | November 7, 2016 05:44 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Problem with total heat transfer rate | aswathy_raghu | FLUENT | 0 | July 26, 2016 07:39 |
conduction problem | venkataramana | OpenFOAM | 3 | December 1, 2013 07:30 |
