May 14, 2017, 12:21 |
Two separate meshing in 2D analysis
Robert
Rep Power: 10 |
I conduct 2D analysis of the air flow using Fluent Workbench. In Workbench-Geometry, in analysed domain (please see the attached draft), I want to create two regions for meshing. In the first region the meshing is to be finer, in second region coarser. I split the surface with Tools->Face Split. In Workbench-Meshing the surface split is clearly visible (clicked with mouse region turns into green color) but during meshing, it is still considered as one and I can mesh only entire surface (not selected region). I do not know what should I do and how in order to impose finer meshing in one region and coarser in another one. Please help. Thank you. |
Meshing software comparison | Wikie | Mesh Generation & Pre-Processing | 5 | September 29, 2014 06:09 |
[ANSYS Meshing] Meshing separate parts | Mana | ANSYS Meshing & Geometry | 0 | May 6, 2014 03:06 |
[Other] Meshing for 2D analysis of blower in Hypermesh | Akash C | ANSYS Meshing & Geometry | 0 | January 30, 2013 13:53 |
[GAMBIT] Desperate student needs help meshing 3D GAMBIT model - please help! | lau06165 | ANSYS Meshing & Geometry | 1 | March 22, 2010 01:09 |
i need help meshing a 3d body for lift analysis | chris | FLUENT | 2 | September 19, 2003 02:36 |
