May 19, 2017, 02:38 |
reference value
hayder altharwanee
hi
i want to solve turbulent flow in smooth channel and i have inlet temperature with magnitude of 293 k can i get the reference value 273 k ? is the length in reference value is hydraulic diameter ? |
May 20, 2017, 10:36 |
Lucky
Rep Power: 66 |
The reference values are only needed for post-processing of derived quantities. If you don't use these post-processes quantities you can ignore all the reference values.
Nusselt number needs a reference length and reference conductivity, so you should put the reference length into the reference value. For channel flows, this reference length is usually the hydraulic diameter. However, these are based on convention. There's no rule or law that says you have to use anything. Heat transfer coefficient needs a reference temperature. Whatever your definition of htc is, you should specify that as the reference value. And so on and so on... |
Second Derivative Zero - Boundary Condition | fu-ki-pa | OpenFOAM | 11 | March 27, 2021 04:28 |
LEMOS InflowGenerator | r_gordon | OpenFOAM Running, Solving & CFD | 103 | December 18, 2018 00:58 |
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 | Attesz | OpenFOAM Installation | 45 | January 13, 2012 12:38 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
G95 + CGNS | Bruno | Main CFD Forum | 1 | January 30, 2007 00:34 |
