Solidification-udf problem
Old   May 28, 2017, 10:08
Default Solidification-udf problem
Ibrahim Isah
isah is on a distinguished road
I am working on a solidification project, I want 2 stir the molten metal for 5mins then stop the rotating region from rotating, then open d gate (i.e after 5mins of stir) so that the molten metal can flow out. I want 2 also control d mass flow rate of the solid metal at inlet such that I will introduce it within first 2 mins of impeller rotation i.e first 2 mins of stir.
Pls, I need help in writing d script for
1) d impeller or stirrer motion
2)d gate ctrl
3)mass flow ctrl
The total mass of metal is 10kg
isah is offline   Reply With Quote
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 00:53
udf loading problem santu Fluent UDF and Scheme Programming 1 May 22, 2015 15:47
Vaporization pressure UDF property problem? lehoanganh07 Fluent UDF and Scheme Programming 1 September 13, 2014 10:59
Problem solidification and rotations. KDarinG FLUENT 0 February 13, 2009 07:47
