Needing help in simulating Natural convection in a pool |
May 29, 2017, 10:30 |
Reza.H
hi everyone.
i want to simulate natural convection in an outdoor pool with fluent,the case is a tank with 2 tube connected to a coil and it is 3d-steady filled with water.I use boussinesq for density,but i cant get the right answer.The pressure contour and temperature contour shows no logical answer.i would appreciate any suggestion and help.tnx |
May 29, 2017, 15:11 |
Audrius
Rep Power: 11 |
In Boussinesq is not showed static pressure. Write for me private message, I will try to help for You.
May 29, 2017, 23:19 |
bcs?
Svetlana Tkachenko
This is a public forum and it is better to help in public for everyone else to be able to assist and learn from the discussion.
May I ask the boundary conditions, obtained results and expected results here? |
May 30, 2017, 01:14 |
Reza.H
The problem is showing circulation of water by natural convection in a pool(hot tub) with no pump or any unnatural force(like pumps).i thought maybe temperature bc may help me but the answer showing no circulation or even hotter tank!i need help both in method and bc.
p.s this link shows the exact diagram of what i want to do. https://www.cedartubs.com/storeimage...stallation.gif |
May 30, 2017, 08:06 |
#5 | |
Kal-El
Rep Power: 9 |
fluent, natural convectin |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 00:04 |
Natural convection in the spent fuel pool | Audrius | FLUENT | 3 | June 14, 2015 09:46 |
Problem simulating natural convection tall cavity | natalialissette | FLUENT | 0 | September 24, 2014 16:11 |
natural convection problem with radiation | jorien | CFX | 0 | October 14, 2011 09:26 |
how to set the parameters in simulating the natural convection | hook | FLUENT | 1 | January 17, 2010 01:33 |
