Solid decomposition(BC:coupled&mass flow inlet?) |
June 9, 2017, 12:19 |
Rep Power: 9 |
I'm modeling a solid fuel decomposition problem by using the Arrhenius law. The mass flow rate of hot gas(released by solid decomposition) is related to the surface temperature of solid, so I have to solve solid-fluid conjugated heat transfer. The problem here comes : Can I use both coupled BC & mass flow inlet? I have spent a lot of time on it , but it seems not possible to set both conjugate and mass flow on one boundary. is there any other method to do so? any advice would be greatly appreciated! |
Calculate Mass Flowrate and Mass Flow Averaged Total Pressure at inlet and outlet | coolcrasher | OpenFOAM Post-Processing | 7 | November 4, 2021 04:57 |
mass flow inlet and pressure outlet with target mass flow rate | Zigainer | FLUENT | 13 | October 26, 2018 05:58 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Multiphase Flow BC-Mass Flow inlet not available? | yimingchen.ok@gmail.com | Siemens | 1 | July 18, 2014 06:08 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
