Setting Heat Flux on an interface
Old   June 11, 2017, 18:00
Default Setting Heat Flux on an interface
Ahmad Zueter
azueter is on a distinguished road
Hello All,
I am modeling a parabolic trough collector model which consists of the following parts:
1) Annular Gap (Vacuum) --> OD=0.11m
2) Solid Tube (Steel) --> OD=0.07m
3) Heat Transfer Fluid (oil)--> OD=0.066m
Surely there should be coupled interface model between the annular gap and solid tube in addition to another one between the tube and fluid.
As part of the model, I have non-uniform concentrated heat flux on the outer absorber tube (adjacent to the annular gap). However, I don't see how I can add a heat flux boundary on an interface. Any help here?
I have found that using the hidden-surface (that is built automatically by FLUENT on interfaces) heat generation rate using a very thin layer to give very good approximation of heat flux profile. I just would like to check, is that the correct way to model it?
azueter is offline   Reply With Quote
Old   June 13, 2018, 03:46
canalpk
canalpk is on a distinguished road
Hello azueter,
Did you find any solution for your problem? I am facing the same issue.
canalpk is offline   Reply With Quote
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Udf for moving heat flux in 2D cylindrical geometry devia21 Fluent UDF and Scheme Programming 0 April 20, 2015 01:27
Radiation interface hinca CFX 15 January 26, 2014 18:11
chtMultiRegionFoam heat flux sailor79 OpenFOAM Running, Solving & CFD 0 September 27, 2013 09:08
heat flux on fluid-solid interface does not match Dai CFX 4 October 30, 2006 09:38
