June 13, 2017, 07:44 |
Help to use DO model
Bouras Oussama
Rep Power: 9 |
I'm currently modeling heat transfer by using only radiation. the geometry is complicated but i can say it's like Two concentric cylinders. the inner cylindre generat the heat by Joule effect. and normally the outer cylindre has to warm up. Because of electromagnetic issue, the fluid between the inner and outer cylindre is vaccum. I already know that for S2S model I have to modele the fluid between the cylinders to let fluent calculat the view factors. but i don't think that DO model needs the fluid, so can i just model just the two cylinders. thank you for your help |
kklOmega omega boundary condition at the wall - OF3.0 | Artur | OpenFOAM Running, Solving & CFD | 1 | June 17, 2016 15:42 |
Turbulence model choice | dave13 | CFX | 3 | December 22, 2015 07:12 |
problem with solving lagrange reaction cloud | Polli | OpenFOAM Running, Solving & CFD | 0 | April 30, 2014 07:53 |
manualInjection model in sprayFoam | Mentalo | OpenFOAM Running, Solving & CFD | 1 | April 2, 2014 09:29 |
Problems bout CFD model of biomass gasification, Downdraft gasifier | wanglong | FLUENT | 2 | November 25, 2009 23:27 |
