June 16, 2017, 22:00 |
Mesh problem
Rep Power: 8 |
Hi ,
every time i try to generate the mesh it fail and i got this message : Patch-conforming tetrahedron mesh failed because of an edge intersection in the boundary mesh. A mesh could not be generated using the current meshing options and settings. any solution for that ? pic: http://imgur.com/a/kg1ff |
June 19, 2017, 06:09 |
Suhas
Rep Power: 14 |
Please check your CAD model first. If you are using Ansys workbench then before going to meshing check for correct share topology. |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Dynamic Mesh Problem. | Tom Clark | FLUENT | 10 | June 21, 2021 04:27 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[ICEM] ICEM Structured Mesh Problem | OMJT | ANSYS Meshing & Geometry | 3 | March 22, 2013 10:06 |
[GAMBIT] SOFC crossflow mesh possible problem??? | epc1 | ANSYS Meshing & Geometry | 1 | February 4, 2013 01:57 |
