Modelling closed loop liquid mixing
Old   July 6, 2017, 05:21
Default Modelling closed loop liquid mixing
Dionysis
VictorWUR is on a distinguished road
Hello everyone,
I want to investigate the mixing of two liquids, one coming from a mainline and the other from venturi injectors. I know all the pressures and flows of the system.
My problem is that I don't know how to imitate the effect of a pump in the middle of the system. As you see in the figure, the pressure at the inlet of the venturi injectors is 3 bars, then drops at 0.5 and joins another flow to go to the pump and reach 6.5 bars.
If I set the BC of the inlet to the specific mass flow rate, then the pressure is too low. Then I added a fan BC to imitate the pump, but then because the outlet has higher pressure the flow goes the "wrong" direction and the pressure is too high.
Any ideas?
Thanks!
VictorWUR is offline   Reply With Quote
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 02:36
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 11:04
[DesignModeler] Design modeller vs. Gambit: Solid and Liquid modelling nvarma ANSYS Meshing & Geometry 5 April 9, 2015 16:04
Cooling behavior of liquid aluminum in a closed container §$§eth STAR-CCM+ 15 May 21, 2013 05:29
governing equations for liquid mixing with free surface? phsieh2005 Main CFD Forum 3 October 6, 2009 20:37
