Including extra data in case and data export? |
July 14, 2017, 16:11 |
Rep Power: 10 |
Hello, I have performed a full cfd simulation and I want to transfer the contours to Tecplot and draw them. I use the File -> Export -> Case and Data option to obtain a full model of my simulation so I can extract the necessary data, but when I want to use it in Tecplot only the X Y Z position data is available for drawing the contours and not the temperature data that I need.
I'll gladly be happy if this question is answered ASAP. |
July 15, 2017, 20:08 |
Aureliano Sancho
Rep Power: 12 |
you need to go in file>export>solution data and choose ASCII files and next Temperature. The Fluent will save one file with rows x, y, z and Temperature or any another property, the coordinates x, y and can to be the center of cells or the position of the nodes.
July 16, 2017, 22:27 |
Lucky
Rep Power: 66 |
You need to select the variables you want to write when you do the solution export.
By the way, Tecplot can also directly read the .cas and .dat file. |
July 20, 2017, 01:15 |
#4 | |
Rep Power: 10 |
July 20, 2017, 01:17 |
Rep Power: 10 |
Yes, but reading the .cas and .dat files resulted in the solution data not being read by Tecplot. So I finally used the Export Solution data method to get the temperature data into tecplot. But I would still appreciate a method on how to make the .cas and .dat files include the solution data.
July 20, 2017, 08:36 |
#6 | |
Lucky
Rep Power: 66 |
case and data, export, tecplot, temperature |
[OpenFOAM] How to get the coordinates of velocity data at all cells and at all times | vidyadhar | ParaView | 9 | May 20, 2020 20:06 |
A CFX-POST error (ver 14.5.7) | wangyflp88 | CFX | 2 | July 22, 2017 00:17 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
fluent case n data files not exporting to tecplot | krishna | FLUENT | 2 | February 17, 2007 23:24 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
