direction of rotating blade
Old   July 23, 2017, 17:08
Default direction of rotating blade
quasimodo is on a distinguished road
Hi everyone,
I am making analysis of helicopter rotor blade with Fluent. But unfortunately when i modelled rotor blade, i draw it clockwise direction by mistake. I tried so hard to generate mesh so i don't want to do everything from the very beginning. Does it matter which direction it turns? (I just need Cp values) If it does, can i fix it without doing everything all along?
Thanks in advance.
quasimodo
quasimodo is offline   Reply With Quote
Car external aerodynamic with wheel spinning issue hokhay FloEFD, FloWorks & FloTHERM 2 August 18, 2016 04:23
[TurboGrid] Slotted rotor Blade using Turbogrid drcsm ANSYS Meshing & Geometry 0 March 15, 2016 00:26
Blade rotating in swirling flow Declan FLUENT 1 February 2, 2015 09:28
Centrifugal Pump Simulation Problem! warex FloEFD, FloWorks & FloTHERM 29 September 23, 2014 10:27
Mesh type in rotating blade inside cylinder Mah.tavana Mesh Generation & Pre-Processing 0 July 26, 2014 06:53
